jakegti
vr6 whistling noise
it sounds likes it coming from the left hand side of the bay(as if youre looking at the engine). i can only hear it under load but it definately sounds vacuum related to me. any ideas?
cheers
Could be the sound coming from ISV damper box... Mine is deleted and it make the whistling sound under load not sure if yours is still present.
see second pic from another thread I have found...The black box arrowed I think thats the ISV Damper
viewtopic.php?f=1&t=54565&hilit=isv+damper+pic
Here is a bit more info I found about it from other threads
The plastic box near the throttle body connected to the ISV on OBD1 VR6 motors is the ISV damper. It keeps the ISV a little quiter. Without it you might hear a slight whistle, whine, or airflowing past the ISV when the ISV is in use.
