kevyboy60
G60 management on 16v
Hi chaps
Got a bit of a problem,i am using G managment to run my 16vt the problem i have is that the water temp sensor for the guage on the G is a 2 pin and the one for the valver is a 1 pin , anyone know what i can do to get over this issue.
not sure what sensor an ABF uses ? is it a 2 pin style like the G with the seal and clip?
many thanks Kev.
Been there with Digifart on my older T.16 2.0 corrado mills.
The 9A white headed water temp.sensor(2pin) will work fine,they are also excellent when using Weber/Marelli injection as i've got now,just don't use the shiyte blue headed Weber sensor,1.8KR Bosch sensor is also ideal but has a bigger thread compared to the 9A 2.0 sensor.
Only chip that was worth fitting was an SNS stg.5 version,all the others are total rubbish,Digilag was awful.
Sorted thanks for that, 2 pin 9a sensor it is then.
I used to have a 280bhp g60 turbo before it took a liking to some trees,wrote the car off so decided to put the jabba ihi turbo kit on a kr engine,spoke to jabbas and they seem to think it will be good for 320-350bhp with 1.5 bar map sensor.
thanks again cheers kev.
you will post pics of that job won't you!? :notworthy:
