bhhjor 0 Posted January 20, 2011 All, been trying to get the c back on the road after the snow. The start problems I thought were the cold start valve. By unhooking it works fine so looks like the temp senders. Took off and went to GSF and Eurocp with the codes. However the newone ain't like the old one - see pics. Question - is there a bit you can add to the new one? Looked at electrical spades crimps etc but none seem big enough. What I thought was simple is really :censored: me off. Any ideas? Quote Share this post Link to post Share on other sites
boost monkey 0 Posted January 20, 2011 I've done those on my head before. IIRC, instead of pushing the spade onto the flat connector inline with the sensor, you slide it on at 90 degrees (across the top flat) and it should still work fine. No idea why they changed them. If the spade doesn't fit, you might need to replace the wire connector but it isn't too hard. Quote Share this post Link to post Share on other sites
krnau 0 Posted January 20, 2011 my kr has the round cap type senders. All you have to do is what boostmonkey says. Quote Share this post Link to post Share on other sites
nocrap 0 Posted January 20, 2011 I've done those on my head before. IIRC, instead of pushing the spade onto the flat connector inline with the sensor, you slide it on at 90 degrees (across the top flat) and it should still work fine. No idea why they changed them. If the spade doesn't fit, you might need to replace the wire connector but it isn't too hard. Yep, cut the existing one off the wire and crimp on a female spade. Quote Share this post Link to post Share on other sites
bhhjor 0 Posted January 20, 2011 Cheers guys, off to do this tonight weather permitting. Thanks for your help - wasn't thinking about the 90 degree option - doh! Quote Share this post Link to post Share on other sites
krnau 0 Posted January 20, 2011 Cheers guys, off to do this tonight weather permitting. Thanks for your help - wasn't thinking about the 90 degree option - doh! the 90º option will make you remember us if you ever have to plug/unplug that with a hot engine :lol: Quote Share this post Link to post Share on other sites
