Peteg60
Which oil cooler,
Right, looking at fitting an additional cooler on the g and wondering what row cooler have other peeps gone for? I'm in the process of fitting a fmic an changing to red top injectors.thanks pete
For the majority of mildly tuned G60 engines a Mocal 13 row cooler is plenty sufficient. Anything bigger than this is not necessary unless you start to push out serious bhp. I run a modified RS6 oil and transmission cooler to keep the oil temp sensible. Your aim will be to run a typical oil temp of 92 to 98 degrees.
Great thanks
