slammed16v 0 Posted February 2, 2011 i'm currently taking my engine apart to rebuild the head and do a few mods..... i''ve read on a thread that putting a head gasket from a mk4 12v vr6 on the ealier corrado vr6 engine increases compression slightly giving a bit more power. has anyone else come across this or done it on their car?? i dont know if this just applies to AAA vr's or is to do with american vr's as it was a US thread i read i think. Quote Share this post Link to post Share on other sites
AlgarveVR6 0 Posted February 2, 2011 the aaa's were all 2.8 iirc. all vr6 corrado's in the uk are 2.9 there are 3 types of head gasket I think, but only differ in thickness. the older the car, the thicker it needs to be to take up slack, unless the block and head are reskimmed. correct me if I'm wrong tho, but this was the case when I did mine Dic Quote Share this post Link to post Share on other sites
slammed16v 0 Posted February 3, 2011 cheers dic, how do you mean take up slack? so when you did yours i'm guessing you just used the normal gasket for the engine? Quote Share this post Link to post Share on other sites
AlgarveVR6 0 Posted February 3, 2011 by slack I mean any warping in the head or block, without reskimming mine was a little different cos I had the block and head surfaces polished flat, seeing as the engine was out and being rebored mine was normal gasket at a guess if yours is towards the 150k mark, use the thickest, which I think has 3 holes. they are graded by the holes. If you look at the one thats on, even with the head on, you can see a tab, front right I think that has the part number and the hole or holes in it Hope it helps Dic Quote Share this post Link to post Share on other sites
Diesel Junior 0 Posted February 3, 2011 Hola Algarve! Good advice that BTW, how is the rebuildathon going? Took the car upto Valencia for the F1 testing today it was a good day out, enjoy the photos via the thread i have put up (viewtopic.php?f=17&t=101096). The DJ Quote Share this post Link to post Share on other sites
AlgarveVR6 0 Posted February 4, 2011 one up and running around like it was a happy little puppy again the other is still in the garage, but running, need to sort out brakes (seized), wheels (i pinched them) and a clutch slave cylinder (on order) nearly there now :grin: Quote Share this post Link to post Share on other sites
