jamiehol
VR6 Gearbox woes
Just put a new to the car gearbox in my track VR6, to benefit from a lower final drive.
However got a bit of problem, if I select 1st gear it enages and you get drive through the wheels but you get a horrible grinding noise like the mesh isn't quite right.
I intially thought it might be the cable adjustment but i have tried adjusting it and it made no difference, I even disconnected the cables and just tried engaging the gears manually using the shift tower but I still get the same issue. All the other gears including reverse work perfectly.
Any one got any ideas or suggestions?
