_Meth
16v Head Rebuild...
Ok so im planning on rebuilding my head over the next few weeks, just got a few questions that hopefully someone can answer for me!
1) Its been mentioned that when i take the head off I should lubricate the bores with a bit of oil, anything inparticular?
2) How do I go about timing the engine up before removing the head?
1) When i rebuilt my 16v head i used normal engine oil around the bores.
2)on the camshaft sprocket theres a little notch on it, this should line up with the arrow on the rocker cover, crankshaft puller has a timing mark and should line up with the timing mark on the timing case.
Also there is a wicked how to on Clubgti.
