cheesy
cheesys 16v,Windscreen area rust treatment & new paint
hello all
The 4th Installment
I'm back in corrado ownership with a 2.0L 16v this time
Moonlight Blue Pearl
Lots of History & money spent
Stainless cat back exhaust fitted
Came with an Alpine cd player
Needs some tweaking on the cold start/idleing
Windscreen needs replacing, gonna have a tiny bit of rust treated on top of a pillar when the damaged one comes out
Been 5 years since i last owned a G60, looking forward to having some fun in this one
anyhow here we are
Edited by cheesy
Cheers wompa
Looked at the cold start issue & looks like its the isv after a quick clean
gonna have another go at cleaning it or replace it
Had a nosey at the sunroof as was told it was faulty,
That looks like the typical fault so needs a repair kit
Heater panel lights weren't working, wiring wasnt plugged in so easy fix
Cars been sat for couple of weeks doing nothing, passenger carpet is wet so gonna look into that,
Having a 9A engine delivered today that i'm gonna give a refresh to, and do a few bits & bobs then get it fitted
Welcome back cheesy, thats a really nice straight original Corrado you have there. What sort of economy do you get according to the MFA, will be in UK this summer with a 16v on the shopping list and would be interested to know! Just done 1000km to Madrid and back and got 33 mpg with the cruise control set at 130kmh.....good luck with the car!
Diesel Junior
I havent got it on the road at the minute as theres a few bits & pieces i want to sort out first
havent had much time recently to get anything done
but
picked up a complete b4 moonroof assembly today
so thats the job for tomorrow
Had an uprated headlight loom delivered
today was just to spend a few hours doing a few bits and pieces
So Old sunroof cassette out & the B4 Passat moonroof in
Really easy job to do, airlined out the drain holes
My o.e motor is dead so bolted the passat one up for the time being till a replacement is bought
I've been trying to get the tumblers to retumbler a couple of locks but vw wanted £50
Stripped down the glove box and went old skoll on the barrel. smoothed down worked at treat
Boot lock, well stripped it down gave it all a damm good clean and was fine just got that much crud in it,
it wasn;t operating off the key
does now so good couple cheap fixes
Replaced the seal round the heater ventilation in scuttle bay, old one had seen its day
Tracked down the ABS to a blown bulb, put my test light onto it and stays on all time so need to get the abs ecu read & new bulb unit
thats about all for today, few more bits to look at next week on me days off
Nearly got the colst start idleing sorted, which is down to the isv
Also fitted some all red rears
Not updated this for a little while
Not been to well for a few weeks myself then my grandad passed away,
So,
Purchased some spax adjustables with 40 or 60mm drop
Front strutbrace
Been purchasing lots of bits & pieces for my spare engine
Painted my spare engine black, rocker cover red & inlet manifold satin black
Fitted new flanges, cambelt tension etc, water pump, fitted kr cam, new timing chain
spent the weekend swapping over the engines
got some bits and pieces still to connect bolt up
first off need to sort out a manifold as my o.e was has a crack in it
Not done alot else due to time really
But refitted airbox
Installed new donut seals onto injectors that have been all cleaned out
ht leads fitted
rad refitted & assiociated pipes & wiring
MK4 header bottle & wiring done
Still got thermostat & lower hose to fit
Exhaust manifold when it arrives
fill with fluids
then should be good to prime everything up then fire into life
Well after another few hours working on the car
got the manifold fitted & dowpipe
refitted the inlet manifold & TB & hose to air box
Fitted alt belt & alternator
PS Belt & tensioner set up
Thermostat & housing
Lower hose for rad
Lower hose for water pump to water hard pipe
Filled with fluids, everything primed
And after a little while sparked into life
no apparant leaks so spot on
Also changed the abs light for a new one and works a treat, comes on and off as it should
Picked the car up from having it lowered
Sits well & ride is alot better than i thought it would be
Spax shocks & 60mm springs, Damping adjustable
Not done anything with this for a while,
work & health getting the way
But have fitted g60 brakes, mk4 rear calipers
new solid brake pipe from abs
Had the broken windscreen removed to see the extent of rust damage underneath that needed attention
Then had the bodyshop work there magic ready for the new windscreen going in
looks like you got that rust in time, mine needed welding! and extended further up towards the trim, how much did it cost you to have the screen removed if you dont mind me asking? it took me an a m8 3 hours to cut mine out, was roight a pita , mainly because trim peices were glued in by a screen fitter and my wire kept on getting snagged on em :(
The metal was still solid, bodyshop said there were 2 very small holes appearing at bottom of pass a pillar which they have sorted
windscreen was removed by auto windscreens on insurance, they were happy to come out, take the cracked one out then come back few days later after the work had been done just for the cost of the glass cover on my policy
the screen that was in had been overly added with sealant & may the fitter swear a couple of times on removal, took him about an hour to remove
ah right ok, so your screen needed replaceing anyway? so at the same time you got the rust sorted! 2 birds 1 stone ;)
take a look at my thread,http://the-corrado.net/showthread.php?56705-my-vr6-Shed-on-Wheels-../page4 on page three you can see the bubbles which were prety nasty!! and holes where you described aswell! think because its on a curve and the metals thinner maybe?
picked the car up today and paint work & new windscreen fitment looks spot on
Cars now gone for ignition timing setup, mot, full pressure brake bleed & new battery
Had a quick play on vag.com
Erased a couple of fault codes on the abs & found the tb postion sensor as a fault
ran out of time looking into other things but a great program, first time i ever used it
