nia573
CK 1/4" Dr Socket Set & Long Flexi Screwdriver Set
CK Professional ¼” drive 39-Piece Socket Set T4655
Item is brand new & unused
Forged chrome vanadium steel.
Industrial/professional quality set
Non slip satin chrome plated for resistance to rust and peeling.
Featuring 'Sure-drive' sockets which apply torque to the flat of the nut rather than the corners to avoid rounding off.
Strong steel storage case
13 Sockets, 21 Screwdriver Bits + Drives, ratchets and accessories.
Forged from high grade chrome-vanadium alloy steel - high wear-resistance.
Strong and convenient steel storage case.
Contains one each of:
Sockets:
4, 4.5, 5, 5.5, 6, 7, 8, 9, 10, 11, 12, 13 & 14mm
Sockets bits:
Hexagon 3, 4, 5 & 6mm.
Torx Tamperproof 8, 10, 15, 20, 25, 27, 30 & 40.
PZD 1, 2 & 3. PH 1,2 & 3.
Slotted 4, 5.5 & 7mm
Accessories:
50mm extension
50mm extension/driver.
Universal joint
Adapter
45 tooth quick release ratchet
RRP £67 +
(£53 on eBay!)
£48 posted 1st class recorded delivery
Rolson LONG REACH FLEXIBLE HOSE CLIP SCREWDRIVER - SOCKET DRIVER
Item is new & Unused but packaging is shop soiled
Description-
3pc Flexible Screwdriver Set.
Manufacturer - Rolson.
Soft grip non slip handles.
Fully flexible 500mm shafts.
Total length - 630mm approx.
CRV steel sockets & bits.
Can be used with any 1/4" drive socket.
Can be used with any 1/4" hex drive screwdriver bit.
Ideal for reaching into engine bays.
Supplied with -
Hose clip driver with fixed 7mm socket.
Socket driver with 1/4" square drive.
Screwdriver with 1/4" hex bit drive.
1/4" Drive sockets - 5, 6 & 8mm.
Torx bits - T10, T15, T20, T25, T27 & T30
Slotted bits - 5.5mm & 6.5mm
Phillips bits - PH1 & PH2
£19.50 Posted
Item sent out 1st Class Recorded Signed For
Mike
Bangor N Wales
Edited by VR6
Contact within the thread pls
