waynos
Brake pads
Im looking at getting some replacement brake pads for the corrado. Found a place on the bay that does rear brembo pads. There are two types one has a thickness of 15.2mm and the other is 17.2. For some reason the thicker ones are cheaper. Which ones do i need? They are going on a g60 by the way
ive got this exact same issue mate, for some reason there are 2 different thicknesses. My vin number falls into the thicker pad catagory. But they wont fit in one of the calipers. THey fit in the other, but dont know why. The caliper is different on that side, as i had to replace it with a new one a while ago and it different make and has a different handbrake mechanism.
