philie
Anything I should know before replacing starter motor
Hi guys,
Im fitting a new starter on Thursday and I was just wondering is there anything I should know before I start and possibly injure myself.
Ok but is there anything that can go wrong or is it just straight formard unblot and bolt in the new. Like there is nothing going to fall on me?
Only issue is access but its a straight swap nice and easy
I take it the intercooler pipes need to come out to gain access?
i would put a jack under engine as 1 bolt holds engine mount and can be a bit of a bugger to get back in if engine drops a bit
Ok cool thanks for the heads up.Were is the best place to jack the engine up obviously not at the sump.
i was going to remove mine but am sure i got put off doing it, due to a manual or something saying i could upset the timing?
i might be wrong as i'm no expert but would be handy to know the true answer, i was hoping to just unbolt mine, clean it and put back on.
