knightrider
Rear Shelves in Black
Both N/S and O/S shelves in the boot that support the rear speakers and have the hinges for the rear parcel shelf, in black.
01892 770655
07802 380516
E sussex, nr Gatwick
I have a pair of these as you require, currently in a M Reg 16V I am breaking. I am based in Rustington, West Sussex so not far from you. Interested?
Hi John, thanks. Presumably the hinge part for the parcel shelf are OK both sides? How much do you want if I collect? Are you breaking a car? I only ask as I also need O/S indicator wing repeater, orange, square. Plus I also need an O/S fog/indicator unit - mine works, but it is cracked.
Regards, Nigel Knight
Hi Nigel,
Yes I am breaking an M plater 16v at the mo I can sort you out a side repeater as well. £25.00 for the lot Inc speakers. The fog light is a non starter I'm afraid.
Karl, I added some additional parts further up the post which you may or may not have spotted. O/S fog/indicator (1994 car), O/S indicator repeater. Have you perhaps got the lot?
Nigel.
Thanks for replies everyone. I'm going to take the car down to John for him to give it a once over and fit his headlight loom upgrade, so I'll get the shelves and indicator repeater from him. Going to post a seperate 'wanted' for the O/S fog/indicator unit. I know they are apparently rarer than hen's teeth, but worth a try!
Thanks Nigel for your call and reservation of parts and specialist service works.
I will look forward to seeing you in the near future. The Corrado 2 litre 16v is being stripped of all parts tommorrow, so the parts you required will be available from Wednesday end of play. Best regards, John. JMR
