VWVW
Coolant Header tank options on a Corrado vr6
Hi there
Just wondered what are my options…I think the original VR6 coolant tank is pretty expensive…Iam not to sure about going for the mk4 header tank either as it involves a bit more work with the pipeing to make it work.
What other “plug and play” header tank can be used…I am sure I read before that a Header tank from a VW fox will fit or from a corrado 8V can anyone confirm.
cheers
Hi mate,
The mk4 setup takes literally minutes of work to get right. I've fitted it and even for me it was easy. The locating lug plastic underneath gets cut to become a slot rather than round and the screw holes are slightly moved. My pipework had enough slack in it to reach with no modifying. The connector plug just needs to be removed and the pins be inserted into the mk4 plug. Go for it mate.
