okcid 10 Posted March 20, 2011 http://cgi.ebay.co.uk/VW-Golf-Corrado-G60-1-5-bar-Pressure-Sensor-/290545227745?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item43a5d857e1#ht_534wt_1139 Quote Share this post Link to post Share on other sites
leeeeshad 0 Posted March 20, 2011 You only need that If you are running over 1bar of boost by using a small pully, you wont gain anything just by fitting it. Quote Share this post Link to post Share on other sites
okcid 10 Posted March 20, 2011 yes i understand this, lots of people adv theres not a great difference between the 65mm pully over the 68mm pully on my stage 4 charger. As when you get up the top of the rev range the ISV vents off boost due to the 1bar limit. Is this right? So i was thinking on a 65mm pully and with the boost re routed back into the boost pipes i might be hitting over 1 bar? Quote Share this post Link to post Share on other sites
mimjed 0 Posted March 20, 2011 its good to have but youre missing the part of reprogramming the ecu with the correct values to actually recognise the higher boost. i looked down this route but struggled to find alot on it. the other way is to use a rally ecu (fitted with 1.5 as standard), there like rocking horse **** though. richard is a memeber on here. i believe you can source them cheaper from bar-tek, but i havent looked for a long time. best option - stick some cams in it and enjoy. Quote Share this post Link to post Share on other sites
okcid 10 Posted March 20, 2011 Cool, was unaware the rallye differed, thanks. Any recommendations on cams with my set up? Quote Share this post Link to post Share on other sites
mimjed 0 Posted March 20, 2011 Shrick 276/268 have had good things said about them. Newman are good also. Get headwork done at the same time to make the most of it. Quote Share this post Link to post Share on other sites
okcid 10 Posted March 21, 2011 HEARD GOOD THINGS ABOUT THE SCHRICK CAM, NEED TO START SVING. aS PER USUAL I KEEP THINKING OF MORE AND MORE THINGS. :s LOL Quote Share this post Link to post Share on other sites
