Hewes
Various bits needed to pass MOT
Abs sensors for front, steering column top bearing, o/s/f track rod end, o/s/r axel bush, arb bushes
Cheers
do you need them used ??
you will do better if you go to local shop and buy them new
If I could get used parts in good condition that would be good, vw want £70 ish for 1 sensor!
Try VW Spares.
Prices are not too bad and the parts are usually at the top end of the pattern parts market (ie Febi, Sachs, Mahle) so will last longer than some bits and will fit unlike some of the ebay tat!
so far so good, thanks for the help guys, only 1 thing left, i need an offside rear subframe bush, i cannot seem to locate any on ebay and etka has been down for some time now, if anyone knows where to get one/ has one it would be appreciated
cheers :)
