Stacks$ 10 Posted March 27, 2011 Hi! Having a little problem with the horn! The fuse blew, replaced the fuse, nothing, no clicking down by the relays any more. I've tested the horn straight on the battery all works fine. The horn is receiving live signal but no earth. All working fine at the steering wheel end but not down at the horn, wiring looks fine as far as I can see but not been able to trace all the way yet. Any suggestions greatly recieved. Many thanks oh, it's 2.0 16V Quote Share this post Link to post Share on other sites
Supercharged 2 Posted March 27, 2011 Welcome to the forum. It's usually the wiring at the button that's the issue - especially if you don't hear the relay click. The earth is made through the steering column itself. Quote Share this post Link to post Share on other sites
boost monkey 0 Posted March 27, 2011 Could be the relay itself, but I'm guessing if you've swapped the fuse you have prob tried another relay too. Quote Share this post Link to post Share on other sites
buttles 0 Posted March 29, 2011 The contact ring on the steering wheel boss was dirty on mine. A clean and electro lube later and all fine. Wouldn't account for the fuse gone though. Quote Share this post Link to post Share on other sites
