VR6 Gar
VDO water temp gauge installation. VR
Got a spare one of these so thought I would wire it in.
When my dash gauge was not working I tried wiring it to the yellow water temp sender but this did not work.
Anyone got one fitted, and if so how have you wired it. I.E. where/what type of sender are you using?
what, no one?
I guess it can be a hole filler for now then.
Just ordered a vdo oil temp gauge so i can use other things on my mfa and one of these:cool:
Shame the only 1 of the 6 not working will be the water temp gauge:(
Edited by VR6 Gar
to rigg up a voltage gauge would it be as simple as just connecting it up to the battery positive and negative? lol im not great with sparks cheers.
You need to find an ignition live and an earth behind the dash, otherwise it will still read when the engine is off.
cheers, i just googled for a how to, doesnt seem to bad, deffinatly something i wanna do, its allways handy to know whats going on in that department.
