robrado974
door lock plastics
the piece of plastic that the metal rods attatch to ,so that the door pins can be used , anyone have drivers and passenger side please . regards rob
hi alex ,its the plastic piece inside the door. the rod attaches to this , with the pin screwing on the top of the rod .it has two holes in it ,the other is for the rod that goes to the door lock .its about 40mm in length .think drivers side is white , passenger side is black or the other way round !.
thanks will see what they want and get back to you . not looking forward to fittin em , looks very tight and fiddly to fit !
they were silly money .....59p each ! thanks for the part numbers beastie .regards rob
Buying them is the easy bit, fitting them is a complete pain enjoy :)
