peachers
VR6 - Idling Issues When Warm
Hi,
As per the title, have been having idling issues with my VR6 when warm. Only had the car about a month and was originally having issues when it was cold and wet but a service and new leads/plugs seemed to sort that. Under normal driving it is fine but was city driving today and when I came to a stop at traffic lights, the car would occasionally rev up 1250rpm and then down to 500rpm. It would then idle normally but then drop revs again when I tried to pull off sometimes which made it a bit tricky.
The engine was quite warm at the time (had been sat in traffic and was 19 degrees) so not sure if this a symptom of the ISV needing replaced or just cleaned?
Cheers,
Peter
