Zeal 0 Posted April 10, 2011 hi, i can't find the guide on cleaning the isv, anybody know where it is? Quote Share this post Link to post Share on other sites
Sam.l 0 Posted April 10, 2011 Im also interested in this! Quote Share this post Link to post Share on other sites
emu 0 Posted April 10, 2011 take it of the car, spray few times with carb cleaner and job done Quote Share this post Link to post Share on other sites
Sam.l 0 Posted May 17, 2011 Do you need to wipe it down at all or lterally just take off, spray with carb cleaner, put back on? Forgive my ignorance! Quote Share this post Link to post Share on other sites
Wullie 1 Posted May 17, 2011 I took mine off, sprayed WD40 into it, gave it a shake and was amazed at the crud that came out. Did it a few times till the WD40 stayed clean. After the deed was done the exterior was also clean as a result of the WD 40 going everywhere. 20 mins max from bonnet opening to bonnet closing. Quote Share this post Link to post Share on other sites
Sam.l 0 Posted May 17, 2011 Okey dokey, seems easy enough. Would carb cleaner be better suited or does it really not matter? Quote Share this post Link to post Share on other sites
science 0 Posted May 17, 2011 Carb cleaner is good, Isopropyl Alcohol is better. What I did was; Fill ISV with IPA. Give it a whizz round with a toothbrush, spin mechanism with toothbrush handle, empty. Refill ISV and seal overnight. Empty next day and be amazed by quantity of dirt and metal particulates that come out. Re-lubericate ISV with light machine oil. Notice scratches and chips inside ISV. Buy new ISV. Job Done. Quote Share this post Link to post Share on other sites
Alex_G60_Fanatic 0 Posted May 18, 2011 Notice scratches and chips inside ISV. Buy new ISV. Job Done. :lol: Could have skipped the cleaning bit then... Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted May 18, 2011 There shouldn't be any metal particles inside the ISV! If there are then the motor is f'cked and allowing the blade to make contact with the ISV body. Quote Share this post Link to post Share on other sites
colinstubbs 0 Posted May 18, 2011 I'm guessing VR ISVs are technically more advanced than the early valvers!! Quote Share this post Link to post Share on other sites
