nommie 10 Posted April 10, 2011 my corrado wont start it turns over but will not fire. i put a new coil on it and fuel pump relay and still no joy. any ideas? Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 10, 2011 give us a clue chap. what engine for a start? ill guess at a late valver. any symptoms before this? and have you been changing other parts? whip the ht leads off and look for a spark. loosen the pipe that connects to the fpr and see if fuel squirts out. check voltage on battery. take oil filler cap off and look for mayo..... Quote Share this post Link to post Share on other sites
VR6 0 Posted April 10, 2011 Early vote/suggestion for ignition switch. Quote Share this post Link to post Share on other sites
RW1 0 Posted April 10, 2011 give us a clue chap. what engine for a start? ill guess at a late valver. any symptoms before this? and have you been changing other parts? Earlier post clue ......"will a vr6 exhaust from the cat back fit on to a 2.0 8v?" . Quote Share this post Link to post Share on other sites
nommie 10 Posted April 10, 2011 yeah sorry guys its a 2.0 8v. all that hapend was i stopped to talk to a boy. turned the car off it was running fine before hand. and now just will not start. Quote Share this post Link to post Share on other sites
Abdul 0 Posted April 10, 2011 Early vote/suggestion for ignition switch. Yup, im with you on this... i had the same problem on my last valver. Quote Share this post Link to post Share on other sites
mimjed 0 Posted April 11, 2011 agreed, ignition switch is high on the likely list. coils are utter crap on the 8v's so not a bad thing you changed it. rw1, you clearly have more time on your hands than i do. Quote Share this post Link to post Share on other sites
