bobbymkII
now back fire 9a 16v
car now running...but once heated up ...as i rev car up to 4k let it come back down its self foot off gas it has a slight back fire as revs pass 2k going down....
just fitted new spark plugs ....car runs fine and idles perfect...just back fire slightly .....
bare in mind this car has sat for 6 months off road in scotland over the coldest winter ever...lol...so no idea if this has something to do with it????
or is it overfueling for some reason?????
lambda sensor????
any clues please fire away,,,
try easiest stuff first:-
What state is your battery in?How old is the fuel?In fuel filter clogged?HT leads got any signs of cracks?they can be very,very small cracks but still cause misfire especially when wet
is dizzy timing is out slighty or blue temp sensor is busted?.Remember dizzy timing has to be set dynamicaly ie.. at 2500 rpm with temp sensor disconnected and all electrics off.
a slight back fire means its not running properly even only on overrun.Metering head set right?Injectors spraying correctly?
