jim69-2008
fuel pump relay
hi, i have a 2ltr 16v and the feul pump relay is a bit dodgy its obviously has a loose connection as when i fudge around with it the car start fine??? just wondered if any 1 has pics or knew how to hard wire the relay in???? i know its not the relay as i brought a genunine vw relay :-/
there's a wiring circuit on the relay itself. Could be a loose terminal in the fusebox if the relay is new and know to be good.
thanks mate thats what i thought loose connection im now going to get me mate to hard wire the relay in then shouldnt be a problem
