teveO 10 Posted May 19, 2011 hey guys. my g60 has running problems i was told yesterday to get a coolant sensor. i have fitted a new sensor but still not pulling properly. the car will rev but when coming to idle it nearly cuts out every time? it will start first time every time and rev on the spot with no hesitation. but when it is under load there is no power it wants to rev and will get to 6000 revs but its nothing like it was last week i have checked my air filter, dizzy cap, leads, spark plugs, compression test and all have come back fine there is no leaks in my pipe work for the charger and the charger seems to be fine. any help would be great cheers steve. Share this post Link to post Share on other sites
Supercharged 2 Posted May 19, 2011 Have you checked the pipe from the back of the TB to the ECU? Also check the throttle switches but tbh it could be a lot of things - timing, ignition fault etc Share this post Link to post Share on other sites
teveO 10 Posted May 19, 2011 yea checked the pipe its all ok. what do u mean by throttle switchs? sound stupid lol Share this post Link to post Share on other sites
VR6 0 Posted May 19, 2011 Sorry but it's a lot easier if you stick to one thread: http://direct.the-corrado.net/showthread.php?55926-G60-ENGINE-PROBLEM-please-help!!!! Then people can see what has been suggested already. Share this post Link to post Share on other sites
