nia573 0 Posted June 12, 2011 Sykes Pickavant Timing Belt/Cambelt Tension Gauge 316600V2 • For accurate tensioning of timing belts, minimising the risk of premature failure due to incorrect belt tension • Features remote gauge for ease of access, with oil filled piston • Gauge scale in Kg as recommended by Vehicle Manufacturers & Autodata Supplied with calibration strip • Suitable for use on all Timing Belts, V Belts, Industrial Belts up to 12mm thick Item looks unused & comes in a plastic case (which may have some slight superficial marks from storage on the outside) £95 incl 1st class recorded postage (Over £160 on eBay) Oil Cooler Overall size 260 x 80 x 33mm Core size 190 x 80 x 33mm Im not sure if this is a Universal cooler of for a particular make of car 7 Row Unused but slight indentations from storage as shown - no holes or splits Fixed brackets as shown £25 incl 1st class recorded postage Speedograph Full Flow Foam Air Filters I dont know what engine theyre but thought they may be of use for Dellortos/Webers/Throttle bodies etc?? They’re 170 x 107 x 105mm approx One has a lower mounting plate that has two 50mm dia holes at 90mm ctrs as shown (I assume the other plate can be cut to suit your application All 3 are unused & are just a bit grubby from storage Are they any good for any VAG carb or throttle body applications? £25 + postage? Offers considered on all items Mike Bangor, N Wales Email: mike@mroberts99.fsnet.co.uk Quote Share this post Link to post Share on other sites
