robrado974
coil problem ?
having starting problems on my 92 vr . Cleaned the isv. Changed the plugs and cleaned the lead caps and dizzy. But somtimes she struggles to start , the revs build slowly and are irratic, if you put your foot on the gas a little she will stall. As i said this happens every now and then .Can a coil slowly start to break down through age or would it just die if its getting towards the end of its life ?.regards rob
