hawwy
vag com errors help please loads of errors
VCDS-Lite Version: Release 1.1
Saturday, 18 June 2011, 22:22:24.
Chassis Type: 50 - VW Corrado
Scan: 01,02,03,15,25
Address 01: Engine Labels: 021-906-258.LBL
Controller: 021 906 258 AG
Component: MOTOR PMC 1
Coding: 0261203109
Shop #: 1267357531
VCID: 59C50E67D017
6 Faults Found:
00527 - Intake Manifold Temperature Sensor (G72)
30-00 - Open or Short to Plus
00537 - Shareware Version. To Decode all DTCs
08-10 - Please Register/Activate - Intermittent
00553 - Shareware Version. To Decode all DTCs
29-10 - Please Register/Activate - Intermittent
00533 - Idle Speed Regulation
10-10 - Adaptation Limit Not Reached - Intermittent
00525 - Shareware Version. To Decode all DTCs
29-00 - Please Register/Activate
00513 - Shareware Version. To Decode all DTCs
03-00 - Please Register/Activate
Readiness: N/A
i have just put a new lambda sensor in yesterday
i have got the codes check they are:
oxygen sensor control
idle air contol regulation
mass air flow sensor
o2 sensor voltage low
what do the above mean , i dont know why o2 sensors coming up as i just changed lambda
anybody help me, as cars giving lots of trouble
Can you not clear the codes then run vagcom again, they generaly don`t clear themselv`es clear them then run it again thats what i do with my audi
