jessicaharvey 10 Posted June 29, 2011 :bonk:right i know the whole wheel adapter thing has been done to death but....... mine arrived today 4x100 to 5x130..(will be running d90s) they came with the bolts to bolt them to the hub but my original wheel bolts dont fit....its like they are a size too small (thread not length) is this normal? if so what nuts will fit...size etc... cheers in advance...:bonk: ---------- Post added at 07:35 PM ---------- Previous post was at 06:49 PM ---------- are corrado bolts m12? if so im thinking i need m14s...anyone come across this? Quote Share this post Link to post Share on other sites
leon263 0 Posted July 5, 2011 No problem. All four stud VWs use wheel bolts which have M12x1.5 threads. All five stud VWs use wheel bolts which have M14x1.5 threads. You will require a set of new wheel bolts in M14x1.5 with radiused heads to suit your D90s and adapters. The M14 bolts are 2mm thicker than your original wheel bolts and are the common bolts used on adapters which is why the originals do not fit. Good luck. Quote Share this post Link to post Share on other sites
