trevyt
late kr or 9a pulley wanted aap
hi to all need asap
051145255 vw part number pas pulley
027121031 vw part number water pump pulley
they are either on the late 1.8 16v kr or on the 2.0 16v 9a engines
cash waiting
hopefully some one has some?
cheers :)
Hi i may have what you are looking for,i do have the 027121031 ,that one appears to be a double pulley .the no i have on the pas pulley is 027145255.ill take 20 pounds for the pulleys plus 4 pounds for postage.
let me know ,if this is of use.thanks rod
rod what i want to do is that i have just put a new pas pump on my car (it had the 41mm one on there and now i have put the 52mm right one on) but the pulleys dont line up, read through here and found the part numbers needed and thats what i have quoted, maybe that number is right dont know, but if you think does the job send me pm with your details, take paypal and can you post asap? cheers trevor
---------- Post added at 10:30 PM ---------- Previous post was at 10:25 PM ----------
rod i dont suppose you got the v belts for these as well saves me rushing round to get some?
Hi ,yes i do have the belts,how does 30 all in inc postage sound
Thanks rod
yes you have a deal how do you want paying? paypal ? let me know cheers trevor
just get new mk2 golf items. Much better especially the pump pulley which will be solid.
---------- Post added at 01:04 PM ---------- Previous post was at 01:03 PM ----------
also I wouldn't use 2nd hand belts. Asking for trouble.
Hi trevor,i think the best thing for me to do is to remove the w/pump pulleys & check the inner no.But let me know if you do go down the mk 2 route
thanks rod
ok rod will keep you updated
have you got any part numbers for the mk2 pulleys boost monkey
thanks for all help but now have got the parts needed cheers all and have a good weekend :)
