ryanmac
2.9 vr6 bottome end and cams
Hi all
I am after a 2.9l bottom end. I am not bothered if it is smoky or not aslong as there isn't a hole in the block or the big end bearings are ruined. The engine is going to be stripped down then lightened and balanced. It has to be cheap so my missus doesn't lose it with me.
I am also after a set of 2.9l cams. Again must be cheap and no real damage on the lobes.
Would prefer them to be in Oxfordshire but willing to travel.
Ryan
I have the bottom end and cams also - based in bath, cylinders 1 and 6 are suspicious of mild ovaling, and surface rust of course! Otherwise ok. £90 collected?
Cams for £20.
Tim
