KADVR6 0 Posted July 24, 2011 ok the engine i have at the moment is smoking a little (stem seals) and been speaking to SKIMASK on here about buying he's refurbed engine, when/if i get that engine i will then be spending some money on taking mine out to 3.0ltr with cams etc etc after xmas. but my engine is currently coilpack, and SKIMASKS is a dizzy engine, so can that engine be converted to coilpack?? or can i run mine with dizzy?? dont forget that mine has the obd2 conversion also, so getting confused lol karl Quote Share this post Link to post Share on other sites
Skimask 0 Posted July 24, 2011 (edited) I seem to remember a couple of people on here that has carried out the change from dizzy to coilpack, maybe do a search? Just did! http://the-corrado.net/showthread.php?51828-VR6-Distributor-Engine-change-to-Coil-Pack-Type The top cover and rear cam needs swapped over. The coilpack engine has a cam sensor, and the magnet or whatever, is on the cam.. Edited July 24, 2011 by Skimask Quote Share this post Link to post Share on other sites
alex303 0 Posted July 24, 2011 Karl, yes you most definitely can convert a dizzy engine to Coilpack as i've literally just had this done to mine as i've taken all the major running gear from my 92 dizzy engined VR & put it into a new 94 VR coilpack shell which is very similar to your plan. Pretty sure it was just the end plate (that the dizzy mounts onto) plus an engine sensor & obviously a coilpack itself (in my case) that were changed. HTH, regards, Alex ok the engine i have at the moment is smoking a little (stem seals) and been speaking to SKIMASK on here about buying he's refurbed engine, when/if i get that engine i will then be spending some money on taking mine out to 3.0ltr with cams etc etc after xmas. but my engine is currently coilpack, and SKIMASKS is a dizzy engine, so can that engine be converted to coilpack?? or can i run mine with dizzy?? dont forget that mine has the obd2 conversion also, so getting confused lol karl Quote Share this post Link to post Share on other sites
CorradoVR6-Turbo 0 Posted July 24, 2011 As above the motors are all the same and its only covers etc that determine dizzy or coilpack....easy! Quote Share this post Link to post Share on other sites
KADVR6 0 Posted July 24, 2011 ok cheers james, so come on ade sell me that engine lol Quote Share this post Link to post Share on other sites
Skimask 0 Posted July 25, 2011 Its yours if you want it Karl! Quote Share this post Link to post Share on other sites
