robo22sri 10 Posted August 11, 2011 Hi guys was wondering if anyone knew where to buy some new piston rings and bottom end bearings? I have a leaking rear crank seal and the chain needs to be done also. So am thinking about going belts and braces and having the big end done while i am at it? whjats your thought? Many thanks Rob Quote Share this post Link to post Share on other sites
jimbobbalooba 0 Posted August 11, 2011 Do it, may as well. I'm in the middle of doing the same. Just getting hold of some ARP main studs and cam bolts as well. It's not cheap for all that lot though; with gaskets, bearings, rings, bolts and chains you won't have much change from £750. Bearings and rings can be bought from your local engine builder/engineering company; yell.com to find your nearest. Best of luck. Jim Quote Share this post Link to post Share on other sites
robo22sri 10 Posted August 11, 2011 I keep thinking about getting a 2.8 24v and putting thy units place but wonder what the gains would be?!? And there is the fact a C with it's original 2.9 will be worth more than one with 24v in it later on! So unsure what to do :( Quote Share this post Link to post Share on other sites
