v1ctor 10 Posted August 26, 2011 it keeps overheating, i think there is problems with the fan, the fan wont run with the engine running. ill shut the car off then the fan with come on. but then as soon as i turn the car back on the fan shuts off. and the car is at like 230 degrees Fahrenheit. why??!! its a 1992 vr Quote Share this post Link to post Share on other sites
RW1 0 Posted August 26, 2011 When you running the engine and the engine is off, its using different temperature sensors. So you need to check the following test .... http://the-corrado.net/showthread.php?57685-Corrado-VR6-over-heating-problem-and-fuel-smell.&p=739154#post739154 Also useful background.... http://the-corrado.net/showthread.php?55012-Auxilery-Water-Pump-not-kicking-in . Quote Share this post Link to post Share on other sites
