chefg60
eibach arb bush size?
Hi fitting eibach arb's and front is 22mm thick, anyone know what size bush to fit? assume its 22mm but cant seem to find anything but 18 0r 20mm?
When we fitted mine (with poly bushes), we drilled them out to something like 21.5mm to make them fit and squeezed them on with alot of polyurethane grease. Had no problems later with that.. If that helps :)
I just bought the Powerflex ones for the front arb, and it's called Pff-85-209 and they don't fit the Eibach front arb.
Instead use this model: PFF-85 -210 which is made specifically for use with the Eibach front anti roll bar. The dealer couldn't see them in his list, but found them on the internet.
Cheers,
Redfox.
Edited by Redfox
