dalhalvaig 0 Posted September 12, 2011 Hi Yesterday, I went out to drive the C VR6. Started the engine - cranked and fired OK - then rathern than settling to idle revs just dropped to zero and engine stalled. Tried a few times and it repeated the same, even pressing the throttle to keep the revs up. Went back to it a couple of hours later, same again but the second try it fired up albeit a bit lumpy. Today started OK and drove pretty well OK. Seemed a little uneven, but accel OK and mpg OK. Any ideas? Cheers D Quote Share this post Link to post Share on other sites
Jim 2 Posted September 12, 2011 Did it seem to be running normally for the few seconds before it cut out? Sounds like classic immobiliser problem... Quote Share this post Link to post Share on other sites
dalhalvaig 0 Posted September 12, 2011 yeah...normal start, normal engine sound, then revs just drop. Quote Share this post Link to post Share on other sites
Jim 2 Posted September 12, 2011 Immobiliser definitely. Hit the search... the trick for fixing the problem has been documented many times :) Quote Share this post Link to post Share on other sites
