yacobwood 0 Posted September 12, 2011 Do the Rotor Arms on 2.0 16v's just pull off? As mine seems to be on quite solid Quote Share this post Link to post Share on other sites
Kevin Bacon 5 Posted September 12, 2011 1800 KR 16Vs used to have glued on rotor arms but I don't know if 2.0 16Vs do or not. It's quite a brittle plastic so you can normally just crush the rotor arm with pliers and pick it off in pieces. Quote Share this post Link to post Share on other sites
Jim 2 Posted September 12, 2011 Yep - 2.0 16v ones were glued on too. It's a right royal pain in the ass as you want to be careful not to be too violent on the distributor to risk bending / damaging the arm! But essentially you do need to use a strong set grips as Kev says to crush the ******* off. Quote Share this post Link to post Share on other sites
yacobwood 0 Posted September 12, 2011 Done it. Finally pulled it off :D Quote Share this post Link to post Share on other sites
