alip_corrado
Main engine loom connector
Hi, not sure if title is correct name for the part but taken a few pics to clarify.
I need both the male and female parts that connects the ecu to the engine.
It's the connector in the centre of the following pic:
Close up of male and female parts:
As you can see some water has got in and caused some corrosion of the pins/plugs.
Female sockets:
Male pins:
Ideally someone will cut both parts of the connector of their looms, leaving me about 100mm ish of wire so I can cut my loom and solder in non-corroded connector. If someone has one half or both, I will take whatever I can get.
If no-one is willing to do so, I am happy to buy both looms so I can cut looms or fit entire looms myself.
The corrosion is causing a few faults and is beyond repair as a few of the pins are very weak and wobbly.
I have this - ideally would sell both parts of the loom but then if you are going to cut off and discard might as well just post you the parts you want!!
I reckon £35 posted as that is a little less than what i would get for the looms as a whole.
Tim
Hi Tim,
Sounds good to me. Do you want to pm details for payment/paypal?
---------- Post added at 10:29 PM ---------- Previous post was at 09:57 PM ----------
PS. I could prob do with replacing 1, maybe 2 other connectors that are a part of that loom. I'll post up description + pics at some point tomorrow.
going on holiday tomorrow morning - if you want them in the next week i'll need pics tonight, if not send me a pm re the parts in the next few days.
Tim
