Stiezo
Ignition upgrade
I really wouldn't bother. I've done the MSD coils myself and it wasn't worth the effort. What symptoms has your engine got to suggest it needs a stronger spark?
This coil fits inside the stock ally cradle with some light modification and gives a stronger spark than standard - http://www.bosch-motorsport.de/pdf/components/ignition_coils/3x2.pdf but even then I only did it to ignite turbo boost.
well there isnt really any problems, i was just lookin to get a lil more bang outta this baby. Has alot of stuff done to it, schrick mani, 268 cams, giac chip etc. I was talkin with a buddy and he mentioned maybe upgradin that so i figured id ask around and see what ppls thoughts were.
As above, A 92 VR should have a Distributor anyway - far more reliable that a coil pack!
Look at his signature dude, they're all American tuning parts so I'm guessing that's where he's from :D Not sure the US got a dizzy SLC for emissions reasons.
---------- Post added at 09:47 AM ---------- Previous post was at 09:43 AM ----------
It's not worth it, honestly! Stock coilpacks have been used to ignite 30psi of boost with no issues, so there's plenty of spark for your nasp motor. As they say, a match can burn a house down just as well as a blow torch. If the fuel/air mix is correct, then you only need a small spark to ignite it. Big sparks are generally only needed for 3 reasons:-
1) Poor engine design
2) To mask a poor tune
3) To ignite boost
I've never seen a nasp VR6 needing anything stronger than stock coils :D
alright, ill take the sound advice and leave well enough alone. Anything else outside of a turbo you can think of to get a lil more outta this baby?
