blaarado
seat ibiza gear lever
just thaught id trow this up it might be usefull to somebody, when i was doing my 20vt conversion using a 01 ibiza cupra, i used the gear box from the ibiza so the original gear change cable ends were different from the ibiza ends so i went about seeing if i could fit the whole lot(gear lever and gear lever box and cables) from the ibiza into the corrado, so i took out the corrado stuff and the gear lever box fitted straight in with no modifications whatsoever so now the gear change is much smoother with the new (01) gear change
