stenninski 10 Posted September 25, 2011 just changed the bottom end on my rado for the 9a and kept my kr head. i now have a problem with it not idleing and is really lumpy down low in the revs. the oil and water temps seem to be higher than they were before aswell the oil is up to about 114 and the water temps are upto about 95 please help ive tried loads and cant work it out ---------- Post added at 07:58 PM ---------- Previous post was at 07:21 PM ---------- just had a thought i used a kr top end gasket kit could this be the problem do i need a 9a head gasket Quote Share this post Link to post Share on other sites
aide 0 Posted September 25, 2011 start with the basics, are the cams and the dizzy time up right? kr gasket should be fine btw. Quote Share this post Link to post Share on other sites
stenninski 10 Posted September 25, 2011 ok cool ill get that checked cheers pal Quote Share this post Link to post Share on other sites
stenninski 10 Posted September 29, 2011 all the timing is spot on. theres fuel and spark so guess compression must be the problem the oil breather is chucking quite a bit into the fuel distributor and there was pressure in the rocker cover Quote Share this post Link to post Share on other sites
