mcbettermanpj
Help! ABS Light - Water Temperature Sensor - Door Handle
OK well my Corrado has hit me with 3 issues at once.
ABS Light Staying on after I pull away
Had codes read and replaced 2 front and 1 rear wheel sensor, replace brake pedal sensor and the wiring to it and even the ABS ECU but still the light comes back on and saying it's the brake pedal sensor. Anyone any ideas - could it actually be the brake servo?
Car running rough and not at all when I plugged into the water temperature sensor which I have now replaced twice so its not that sensor.
Maybe the ABS and the water temperture sensor are down to ageing wiring so anyone know if you can get just the wiring loom for the engine?
Drivers door again broken but the part that has broken is not the normal part that goes - where can I get a cheap door handle?
It could be coming to the time I just decide to wave white flag and sell it :(
