AB 0 Posted October 20, 2011 my car runs fine but on first start up only first one of the day i have to help it keep idle, i have changed the idle valve and blue temp sensor. i unplugged the stepper motor on the throttle body and it starts from cold fine. i ran a vag com scannerand got the fault code 00533 - idle speed regulation could any one shed some light on this please? thanks Quote Share this post Link to post Share on other sites
RW1 0 Posted October 20, 2011 Take a look at the duct between the MAF and Throttle Body, particulalry the bellows for a split in the creases. Look for an air leak. . Quote Share this post Link to post Share on other sites
AB 0 Posted October 22, 2011 no splits in that. any other clues towards this fault code please? Quote Share this post Link to post Share on other sites
AB 0 Posted October 28, 2011 anyother ideas on this please : ( Quote Share this post Link to post Share on other sites
Nathan Harvey 10 Posted October 28, 2011 My mate had a similar problem on his mk2 gti 8v , got a new maf and worked fine again. have you tired cleaning the maf ? or just try disconnecting it see what happens? Quote Share this post Link to post Share on other sites
AB 0 Posted October 28, 2011 if its running and i unplu it then the revs drop and it struggles to run so i presumed it was ok. whats the best way to clean one? thanks Quote Share this post Link to post Share on other sites
Nathan Harvey 10 Posted October 28, 2011 In the past i've disconnected one, the car ran rich and idled . I used lec clean (electrical component cleaner) and just make sure it was dry before re-installing and starting. Clean the throttle body with some carb cleaner? Quote Share this post Link to post Share on other sites
AB 0 Posted October 28, 2011 ok thanks will unplug when its cold again in the morning. Quote Share this post Link to post Share on other sites
