everard90
hi info on having a stage 5 rebuild
as title thinking of having mu charger dun to stage 5 other than the 68mm pully and chip anything else need chaging to acomadate this
You would be best giving JMR a ring, John will give you some good advice on it. He will be the man to do it if you choose to proceed
Thanks for the shout Rustynuts, allways appreciated. As part of our VAG specialist services, we have been carrying out charger rebuilds and porting since the early 90's, so indeed would be happy to advise and complete works as required for those interested. We are closed for a break now until our return on 31st October. Will be happy to talk with you at this time. Our contact number is 01903 718684. I look forward to hearing from you.
hi how much do you charge for a stage 4 rebuild and a map to sute ?
how much for a stage 5 rebuild and map and what else dose this need ?
