Asif 0 Posted October 26, 2011 1. My VR6's cooling fans dont want to go off and its killing my battery... 2. Drivers heated seat not working but the passenger seats perfect. You can hear the relay clicking in the nsr arch when turning the heated passenger seat on. Anyone had this problem? Quote Share this post Link to post Share on other sites
VW_OwneR_85 2 Posted October 26, 2011 think it may have something to do with the rad stat or its plug, its on the lower right side of rad {if your faceing the car} have a look and unplug it see if it stops, im sure someone with more experiance will post up. Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted October 26, 2011 Yeah check the rad switch, as VR_owner said its the bottom right of the rad down below the battery. Failing that it could be the fan control box which sits in front of the coolant expansion tank. But check the rad switch first :D Quote Share this post Link to post Share on other sites
Rams 0 Posted October 28, 2011 1. My VR6's cooling fans dont want to go off and its killing my battery... 2. Drivers heated seat not working but the passenger seats perfect. You can hear the relay clicking in the nsr arch when turning the heated passenger seat on. Anyone had this problem? I had the same problem with my drivers heated seat when I first got my C, it was a soldered connection that had broken off, just needed re soldered and all was fine. Eact symptoms. Its just where you get in and out, especially the driverside and the movement distrurbs the connection. You have to take the seat out, unclip the springs holding the material and with a sharpe knife gentle cut the white fabric that sandwiches the wire / heating element and find where its disconnected. Usually its the join where it loops back to itself. My thread has a picture of this somewhere. Quote Share this post Link to post Share on other sites
Asif 0 Posted October 30, 2011 Thanks guys il check it out.... :) Quote Share this post Link to post Share on other sites
Asif 0 Posted December 18, 2011 Thanks guys il check it out.... :) I have found the problem with the cooling fans not going off.... Finally... In the engine bay on the right hand side next to the water tank and washer fluid tank theres a black like relay block with 2 x 10mm bolts and a see through cover with the numbers 506................ 5amp and 20amp.... I have just tapped it and they have gone off!!! Must be a dodgy sticking relay or a bad connection. I think I will be stripping it down and giving it a good clean. Just glad they have gone off and are not killing the battery anymore...:) Quote Share this post Link to post Share on other sites
Asif 0 Posted December 18, 2011 Found the fault with the drivers heated seat with it not working. I have taken some pictures for anyone that might be interested :) Quote Share this post Link to post Share on other sites
Asif 0 Posted December 18, 2011 (edited) Taken drivers seat out. Loosed the 10mm bolt on the front of the seat. Pushed chair right back and it slid straight out. Had to strip bottom half of seat which was took some time. Slowly pulled the (heater element) from seat. Checked cables and did a continuity test. Found a bad soldering connection and a break. Resoldered and cured fault. Put everything back together... Can be time consuming if its your first time. Edited December 18, 2011 by Asif ... Quote Share this post Link to post Share on other sites
