Stonejag
Front + rear calipers (mk4 / 288)
Need to sort out all the bits for an all-round brake upgrade - a rear wheel bearing's gone along with the beam bushes being perished so it makes sense to do everything at the back at once while they've got the beam off. While they're bleeding those they may as well be bleeding some new fronts too...
So I need some mk4 rear calipers (with or without pads but I'll need good seals) and some 288 fronts with the carriers. I'm happy to sort out all the hoses, pads and discs, just need to crack on and get everything in one place :)
Cheers
Stone
I have a full black powdercoated rear axel, with VAG bushes, VAG discs and pads, VAG brake shields, bearings, handbrake cables, brake flexi hoses and a fresh brake compensation valve. I'll also include any copper pipes which were done at the same time.
Since the refurb its covered 6,000 miles max. All nice and fresh just needs a quick clean... So it'd be literally the case of you swapping your axel for this with no messing about.
£250. Located in Sheffield, I can post at cost.
Edit. Just realised this is for a G60 so it's 4x100.
Rich.
Edited by P3rks
Yep, sorry, mine's a VR. Also would have been a much better deal if I hadn't already bought new bushes and bearings...! Thanks anyway though.
Hi Stonejag, we met at the Bealieu meet recently. I am about to upgrade the front brakes on my Audi A4 Quattro Sport, which is currently fitted with 288's. These are in very good condition and painted silver. I can supply you with callipers and carriers to suit. If you are interested give me a call
Tommorrow at the workshop.
Best regards, John JMR 01903718684
I've got a set of 312mm S3 fronts. Got a nearly new set of brembo pads in them (done 1000 miles max) and a good set of discs with them. Looking for £160
Also got a good set of Mk4 rear calipers £50
PM me if you interested.
