duckdown_hoodrat
KR Losing power/popping from exhaust
Hi Guys,
My rado has developed a problem where once up to temp/after 15/20 mins driving there is a noticeable drop in power (very flat), becomes very loud through exhaust and pops on over run.
There is no juddering at all but does sometimes need a bit of gas to start. so any ideas what i should try first?
Dan
That sounds very similar to mine when the Crank bolt loosened and allowed the crank pulley to move out of alignment. A quick check is to compare the positions of the timing marks on the crankshaft pulley and the flywheel. If all is OK they should line up. You may notice the crank pulley wobbling when the engine is running if the bolt has loosened.
