priceyslayerman 10 Posted November 20, 2011 hey guys. ive just had new wheels put on my vr6 and have adjusted the camber on the front back to normal as i had quite a lot of camber on the old wheels. After i had done this it seems that the passenger side wheel is very straight and the drivers side wheel has quite a bit more camber to it. I was thinking that it could be the top mounts but wanted to get some suggestions before i start buying things. Cheers, Pricey Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 20, 2011 Have you adjusted the camber yourself? How did you do it - normally lasers are used to adjust the geometry. Did you check both sides? Quote Share this post Link to post Share on other sites
priceyslayerman 10 Posted November 20, 2011 My friend has adjusted camber on all sort of VW's and cant seem to figure out why it wont go straight. The passenger side is completly straight to the eye but you can see a considerable difference with the drivers side. The person who had the car before me did a ban job of fitting the coilovers by putting the top mounts upside down and other things but we changed that. We also noticed that there are thread lock nuts instead of the special nuts you get with a top mount kit fitted, Could that be the problem? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 20, 2011 I cant see the top mount nut being the problem, whats wrong with the drivers side - too much negative or too much positive camber? Id be checking the top mounts are fitted correctly, nothing bent? Quote Share this post Link to post Share on other sites
priceyslayerman 10 Posted November 20, 2011 Well im going to be getting new top mounts shorty as i want everything working as it should but there is a bit to much negative camber. My mate said that his 6n always had a bit more on his drivers side wheel than his passenger so was thinking it might be a factory thing? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted November 20, 2011 No its not a factory thing. Quote Share this post Link to post Share on other sites
dr_mat 0 Posted November 21, 2011 If it's not possible to even up the camber, either you're not doing it right .. :) .. or something is bent .. either the strut itself or the hub assembly where it fits onto it. Quote Share this post Link to post Share on other sites
