carrots 1 Posted November 26, 2011 hi ive got a coulple of electric problems on the corrado.1st is the dam coolant light flashing and second is the blower stopping working sometimes.if i wiggle the relay the blower starts working again so do you reckon if i spray contact cleaner on the fuse box it could cure it.i am sure i changed number 14 relay in the past and that cured the coolant light,but i fitted a 2nd hand relay.any other ideas Quote Share this post Link to post Share on other sites
dannyboy 0 Posted November 26, 2011 i would check to see if the connections have splayed out and check for corrosion.Get a torch and youself down that footwell and check connections. Water seems to get in on the bulkhead and first place it drops on is the fusebox,great! Quote Share this post Link to post Share on other sites
carrots 1 Posted November 26, 2011 (edited) ive taken the relays out and sprayed contact cleaner in there.took the plug off expansion tank and sprayed it in there.all seems good.the lights gone off for coolant and blower and wipers ok.i did change number 18 relay for a 2nd hand un i had,1 terminal looked a bit burnt Edited November 26, 2011 by carrots Quote Share this post Link to post Share on other sites
