_Rich_
rear brakes
can anyone shed a bit of light on the whole fitting mk4 rear brake calipers to a corrado please? ive done a search but cant find any info?
basically what are the advantages on a 91 g60?
what is needed to do it? (4 stud car)
regards
rich
It's all in the stickied post immediately above this one ;) (link)
The mk4 calipers are less likely to seize on because VW redesigned the handbrake mechanism. Should just be a case of taking the old calipers off the carrier, swapping the new ones onto the existing carriers and using Goodridge conversion hoses to hook them up. Probably a sound longer-term investment but I don't see much point unless your calipers are already sticking - I'm only doing mine because the rear beam has to come off to do the bushings and wheel bearings...
Stone
