CorradoWannabe 1 Posted December 8, 2011 A very newbie question here but I've read different things. The Corrado I'm after has Milltek 2.5” stainless steel exhaust (de-cat) - now i've seen some people say that you cannot get an MoT if you have de-cat your exhaust? Is this true? Are some garages stricter than others? Will emissions test etc still pass? Quote Share this post Link to post Share on other sites
Critical_Mass 10 Posted December 8, 2011 A sensor is put up the tail pipe which cant lie or be lenient. Though you maybe able to find a garage that may put the sensor up a different tail pipe. Its not a case of it failing if it doesnt have a cat, its a case that the emissions will be higher with out one and therefore could fail the MOT. You'll probably need a cat during MOT time, but nothing saying you cant put one on for MOT time ;) A sports cat is another option. Quote Share this post Link to post Share on other sites
StueyB 0 Posted December 8, 2011 Pretty sure age of car is the key here. Also something about Pre-Aug 92 springs to mind. What I can tell you for sure is that I've attempted to have my car MOT 2 years running with the decat still fitted and emissions were a long way off passing. (95 VR6). Quote Share this post Link to post Share on other sites
VAG-hag 0 Posted December 8, 2011 I thought that if cars had them as std they must have one for the test regardless of emissions? Quote Share this post Link to post Share on other sites
mimjed 0 Posted December 8, 2011 It's part of the mot to check the condition of the exhaust, mainly looking for leaks. If there is no cat present on a post august 92 car they can indeed fail it. To be honest if a garage didn't notice it I wouldn't be sending my car to them for any repair work. As said best bet is to change the decat pipe over for the mot. But yes some garages will turn a blind eye to it. Sat morning is the normal day for things to be inspected by stevie wonder ;) Quote Share this post Link to post Share on other sites
StueyB 0 Posted December 8, 2011 Sat morning is the normal day for things to be inspected by stevie wonder ;) Classic. Quote Share this post Link to post Share on other sites
dannyboy 0 Posted December 8, 2011 any car before april 1992 doesnt require a Cat and is allowed 3.5% CO by volume and 1200 HC ppm.After that you require a Cat and are only allowed 0.3% and 600 HC ppm. Pays to have a earlier car as the limit is quite generous. Quote Share this post Link to post Share on other sites
